| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » netdiag /fix |
netdiag /fix
Сообщения: 595 |
Здравствуйте!
Снес на Вин 2003 Сервер DNS, AD не трогал. Настроил DNS, но записей SRV нет и нет других служебных записей. Только зоны. Не могу подключить клиентску машину к домену, ругается на отсутствие SRV записи. Запустил команду netdiag /fix. Но ничего не изменилось. Вот лог. Computer Name: SERVER2 DNS Host Name: server2.mou102.local System info : Microsoft Windows Server 2003 (Build 3790) Processor : x86 Family 15 Model 4 Stepping 1, GenuineIntel List of installed hotfixes : KB914783 Q147222 Netcard queries test . . . . . . . : Passed GetStats failed for '╧Ё*ьющ ярЁрыыхы№э√щ яюЁЄ'. [ERROR_NOT_SUPPORTED] [WARNING] The net card '╠шэшяюЁЄ WAN (IP) - ╠шэшяюЁЄ яырэшЁют∙шър яръхЄют' m ay not be working because it has not received any packets. [WARNING] The net card '╠шэшяюЁЄ WAN (PPTP)' may not be working because it h as not received any packets. [WARNING] The net card '╠шэшяюЁЄ WAN (PPPoE)' may not be working because it has not received any packets. [WARNING] The net card '╠шэшяюЁЄ WAN (IP)' may not be working because it has not received any packets. GetStats failed for '╠шэшяюЁЄ WAN (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : ─юьхэ Netcard queries test . . . : Passed Host Name. . . . . . . . . : server2 IP Address . . . . . . . . : 192.168.0.40 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : 192.168.0.40 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Adapter : ADSL Netcard queries test . . . : Passed Host Name. . . . . . . . . : server2 IP Address . . . . . . . . : 0.0.0.0 Subnet Mask. . . . . . . . : 0.0.0.0 Default Gateway. . . . . . : NetBIOS over Tcpip . . . . : Disabled Dns Servers. . . . . . . . : 192.168.0.40 IpConfig results . . . . . : Failed Pinging DHCP server - not reachable WARNING: DHCP server may be down. AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Skipped NetBT is disabled on this interface. [Test skipped] WINS service test. . . . . : Skipped NetBT is disable on this interface. [Test skipped]. Adapter : {EDCCF901-981E-4BC7-8215-7F9C024F1105} Netcard queries test . . . : Passed Host Name. . . . . . . . . : server2 IP Address . . . . . . . . : 77.243.112.163 Subnet Mask. . . . . . . . : 255.255.255.255 Default Gateway. . . . . . : 77.243.112.163 NetBIOS over Tcpip . . . . : Disabled Dns Servers. . . . . . . . : 77.243.112.34 77.243.113.34 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed NetBT name test. . . . . . : Skipped NetBT is disabled on this interface. [Test skipped] WINS service test. . . . . : Skipped NetBT is disable on this interface. [Test skipped]. Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{7A9F27A8-4CC3-41BC-B092-59102EBB2BEF} 1 NetBt transport currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Servi ce', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Failed [FIX] re-register DC DNS entry '_ldap._tcp.mou102.local.' on DNS server '192 .168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.Default-First-Site-Name._sites.mo u102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.pdc._msdcs.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.030f99c1-febb-4aaa-bdd2-baf1c77e6 dc7.domains._msdcs.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '05c245be-2eb0-4c46-bdeb-31a2b20324c3._msdcs. mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kerberos._tcp.dc._msdcs.mou102.local.' on D NS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kerberos._tcp.Default-First-Site-Name._site s.dc._msdcs.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.dc._msdcs.mou102.local.' on DNS s erver '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.Default-First-Site-Name._sites.dc ._msdcs.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kerberos._tcp.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kerberos._tcp.Default-First-Site-Name._site s.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kerberos._udp.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kpasswd._tcp.mou102.local.' on DNS server ' 192.168.0.40' succeed. [FIX] re-register DC DNS entry '_kpasswd._udp.mou102.local.' on DNS server ' 192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.DomainDnsZones.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.Default-First-Site-Name._sites.Do mainDnsZones.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.ForestDnsZones.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.Default-First-Site-Name._sites.Fo restDnsZones.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.gc._msdcs.mou102.local.' on DNS s erver '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_ldap._tcp.Default-First-Site-Name._sites.gc ._msdcs.mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry '_gc._tcp.mou102.local.' on DNS server '192.1 68.0.40' succeed. [FIX] re-register DC DNS entry '_gc._tcp.Default-First-Site-Name._sites.mou1 02.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry 'mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry 'gc._msdcs.mou102.local.' on DNS server '192. 168.0.40' succeed. [FIX] re-register DC DNS entry 'mou102.local.' on DNS server '192.168.0.40' succeed. [FIX] re-register DC DNS entry 'gc._msdcs.mou102.local.' on DNS server '192. 168.0.40' succeed. FIX PASS - netdiag re-registered missing DNS entries for this DC successfull y on DNS server '192.168.0.40'. [FATAL] No DNS servers have the DNS records for this DC registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{7A9F27A8-4CC3-41BC-B092-59102EBB2BEF} The redir is bound to 1 NetBt transport. List of NetBt transports currently bound to the browser NetBT_Tcpip_{7A9F27A8-4CC3-41BC-B092-59102EBB2BEF} The browser is bound to 1 NetBt transport. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Passed Entry Name: IREN Device Type: Framing protocol : PPP LCP Extensions : Enabled Software Compression : Disabled TCP/IP IP Address : Server Assigned Name Server: Specified IP Header compression : Disabled Use default gateway on remote network : Enabled Connection Statistics: Bytes Transmitted : 158153 Bytes Received : 443360 Frames Transmitted : 627 Frames Received : 648 CRC Errors : 648 Timeout Errors : 0 Alignment Errors : 0 H/W Overrun Errors : 0 Framing Errors : 0 Buffer Overrun Errors : 0 Compression Ratio In : 0 Compression Ratio Out : 0 Baud Rate ( Bps ) : 100000000 Connection Duration : 764672 Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Прошу помощи, пожалуйста. Спасибо |
Отправлено: 07:45, 12-12-2008 |
Профиль | Отправить PM | Цитировать Сделал:
1) На ДНС зона АД интегрированная? Сделай обычную (не интегрированную) - легко меняется на лету 2) Разреши в свойствах Zone Transfer брать зону всем (на время) 3) Останови днс сервер сервис. Скопируй файл WINDOWS\system32\config\netlogon.dns в \WINDOWS\system32\dns\ZONE.dns (ZONE переименуй в имя твоей зоны) 4) Стартани на днс сервис 5) переведи зону в интегрированную Может кому пригодится. |
Отправлено: 08:06, 12-12-2008 | #2 |
| Ошибка - [решено] не работает netdiag | toro | Microsoft Windows 2000/XP | 2 | 28-11-2009 12:37 | |
| Не могу разобраться с диагностикой netdiag. | testik777 | Microsoft Windows NT/2000/2003 | 8 | 24-10-2008 09:31 | |
| Система - [addon] NetDiag | IDDQDesnik | Наборы обновлений для Windows XP/2003/Windows 7 | 7 | 09-07-2008 13:30 | |
| Сообщение об ошибке Netdiag.exe | maxo | Microsoft Windows NT/2000/2003 | 5 | 06-05-2008 17:02 | |
| Dcdiag и netdiag | paha72 | Microsoft Windows NT/2000/2003 | 6 | 29-05-2007 09:42 | |
