| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » [решено] проблема с dns или AD |
Старожил Сообщения: 166 |
доброго времени суток!
win2003 st.ed. sp2 ad+dns. только pdc xp prof sp3 у меня вот такая проблема: Microsoft Windows [Версия 5.2.3790] (С) Корпорация Майкрософт, 1985-2003. C:\Documents and Settings\mafik>g:\dcdiag.exe Domain Controller Diagnosis Performing initial setup: Done gathering initial info. Doing initial required tests Testing server: Default-First-Site-Name\DC Starting test: Connectivity ......................... DC passed test Connectivity Doing primary tests Testing server: Default-First-Site-Name\DC Starting test: Replications ......................... DC passed test Replications Starting test: NCSecDesc ......................... DC passed test NCSecDesc Starting test: NetLogons ......................... DC passed test NetLogons Starting test: Advertising ......................... DC passed test Advertising Starting test: KnowsOfRoleHolders ......................... DC passed test KnowsOfRoleHolders Starting test: RidManager ......................... DC passed test RidManager Starting test: MachineAccount ......................... DC passed test MachineAccount Starting test: Services ......................... DC passed test Services Starting test: ObjectsReplicated ......................... DC passed test ObjectsReplicated Starting test: frssysvol ......................... DC passed test frssysvol Starting test: frsevent ......................... DC passed test frsevent Starting test: kccevent ......................... DC passed test kccevent Starting test: systemlog ......................... DC passed test systemlog Starting test: VerifyReferences ......................... DC passed test VerifyReferences Running partition tests on : ForestDnsZones Starting test: CrossRefValidation ......................... ForestDnsZones passed test CrossRefValidation Starting test: CheckSDRefDom ......................... ForestDnsZones passed test CheckSDRefDom Running partition tests on : DomainDnsZones Starting test: CrossRefValidation ......................... DomainDnsZones passed test CrossRefValidation Starting test: CheckSDRefDom ......................... DomainDnsZones passed test CheckSDRefDom Running partition tests on : Schema Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Running partition tests on : Configuration Starting test: CrossRefValidation ......................... Configuration passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDRefDom Running partition tests on : local Starting test: CrossRefValidation ......................... local passed test CrossRefValidation Starting test: CheckSDRefDom ......................... local passed test CheckSDRefDom Running enterprise tests on : local.istok.net Starting test: Intersite ......................... local.istok.net passed test Intersite Starting test: FsmoCheck ......................... local.istok.net passed test FsmoCheck C:\Documents and Settings\mafik> C:\Documents and Settings\mafik>g:\netdiag.exe ....................................... Computer Name: DC DNS Host Name: dc.local.istok.net System info : Windows 2000 Server (Build 3790) Processor : x86 Family 15 Model 67 Stepping 3, AuthenticAMD List of installed hotfixes : KB957097 KB958644 KB958687 Q147222 Netcard queries test . . . . . . . : Passed [WARNING] The net card 'VMware Virtual Ethernet Adapter for VMnet8' may not be working because it has not received any packets. [WARNING] The net card 'VMware Virtual Ethernet Adapter for VMnet1' may not be working because it has not received any packets. GetStats failed for '¦Ё*ьющ ярЁрыыхы№эvщ яюЁЄ'. [ERROR_NOT_SUPPORTED] [WARNING] The net card '¦шэшяюЁЄ WAN (PPTP)' may not be working because it h as not received any packets. [WARNING] The net card '¦шэшяюЁЄ WAN (PPPoE)' may not be working because it has not received any packets. [WARNING] The net card '¦шэшяюЁЄ WAN (IP)' may not be working because it has not received any packets. GetStats failed for '¦шэшяюЁЄ WAN (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : ¦юфъы¦ўхэшх яю ыюъры№эющ ёхЄш Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc IP Address . . . . . . . . : 192.168.10.3 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : 192.168.10.3 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. No remote names have been found. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Adapter : VMware Network Adapter VMnet1 Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc IP Address . . . . . . . . : 192.168.217.1 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. No remote names have been found. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Adapter : VMware Network Adapter VMnet8 Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc IP Address . . . . . . . . : 192.168.118.1 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. No remote names have been found. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{6FC65342-2D8E-4976-AAFD-C9DCFD31D691} NetBT_Tcpip_{8C053946-7C97-4780-B06C-68796700B795} NetBT_Tcpip_{825E9C9D-00D8-427C-AF56-FBDD9815620D} 3 NetBt transports currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Failed [FATAL] NO GATEWAYS ARE REACHABLE. You have no connectivity to other network segments. If you configured the IP protocol manually then you need to add at least one valid gateway. NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Servi ce', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Failed [WARNING] Cannot find a primary authoritative DNS server for the name 'dc.local.istok.net.'. [ERROR_TIMEOUT] The name 'dc.local.istok.net.' may not be registered in DNS. [WARNING] Cannot find a primary authoritative DNS server for the name 'dc.local.istok.net.'. [ERROR_TIMEOUT] The name 'dc.local.istok.net.' may not be registered in DNS. [FATAL]: The DNS registration for 'dc.local.istok.net' is incorrec t on all DNS servers. PASS - All the DNS entries for DC are registered on DNS server '192.168.10.3 ' and other DCs also have some of the names registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{6FC65342-2D8E-4976-AAFD-C9DCFD31D691} NetBT_Tcpip_{8C053946-7C97-4780-B06C-68796700B795} NetBT_Tcpip_{825E9C9D-00D8-427C-AF56-FBDD9815620D} The redir is bound to 3 NetBt transports. List of NetBt transports currently bound to the browser NetBT_Tcpip_{6FC65342-2D8E-4976-AAFD-C9DCFD31D691} NetBT_Tcpip_{825E9C9D-00D8-427C-AF56-FBDD9815620D} NetBT_Tcpip_{8C053946-7C97-4780-B06C-68796700B795} The browser is bound to 3 NetBt transports. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Passed Service status is: Started Service startup is: Automatic IPSec service is available, but no policy is assigned or active Note: run "ipseccmd /?" for more detailed information The command completed successfully C:\Documents and Settings\mafik>
C:\Documents and Settings\mafik>nslookup Default Server: dc.local.istok.net Address: 192.168.10.3 > dragon.local.istok.net Server: dc.local.istok.net Address: 192.168.10.3 DNS request timed out. timeout was 2 seconds. Name: dragon.local.istok.net Address: 192.168.10.12 > > altair.local.istok.net Server: dc.local.istok.net Address: 192.168.10.3 DNS request timed out. timeout was 2 seconds. Name: altair.local.istok.net Address: 192.168.10.14 C:\Documents and Settings\mafik>ipconfig -all Настройка протокола IP для Windows Имя компьютера . . . . . . . . . : dc Основной DNS-суффикс . . . . . . : local.istok.net Тип узла. . . . . . . . . . . . . : неизвестный IP-маршрутизация включена . . . . : нет WINS-прокси включен . . . . . . . : нет Порядок просмотра суффиксов DNS . : local.istok.net istok.net Подключение по локальной сети - Ethernet адаптер: DNS-суффикс этого подключения . . : Описание . . . . . . . . . . . . : NVIDIA nForce Networking Controller Физический адрес. . . . . . . . . : 00-1E-8C-0A-71-05 DHCP включен. . . . . . . . . . . : нет IP-адрес . . . . . . . . . . . . : 192.168.10.3 Маска подсети . . . . . . . . . . : 255.255.255.0 Основной шлюз . . . . . . . . . . : DNS-серверы . . . . . . . . . . . : 192.168.10.3 VMware Network Adapter VMnet8 - Ethernet адаптер: DNS-суффикс этого подключения . . : Описание . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet 8 Физический адрес. . . . . . . . . : 00-50-56-C0-00-08 DHCP включен. . . . . . . . . . . : нет IP-адрес . . . . . . . . . . . . : 192.168.118.1 Маска подсети . . . . . . . . . . : 255.255.255.0 Основной шлюз . . . . . . . . . . : VMware Network Adapter VMnet1 - Ethernet адаптер: DNS-суффикс этого подключения . . : Описание . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet 1 Физический адрес. . . . . . . . . : 00-50-56-C0-00-01 DHCP включен. . . . . . . . . . . : нет IP-адрес . . . . . . . . . . . . : 192.168.217.1 Маска подсети . . . . . . . . . . : 255.255.255.0 Основной шлюз . . . . . . . . . . : C:\Documents and Settings\mafik> на всех клиентах Тип события: Ошибка Источник события: Userenv Категория события: Отсутствует Код события: 1054 Дата: 17.02.2009 Время: 1:54:27 Пользователь: NT AUTHORITY\SYSTEM Компьютер: DC Описание: Не удалось получить имя контроллера домена в этой сети. (Непредвиденная сетевая ошибка. ). Обработка групповой политики прекращена. Дополнительные сведения можно найти в центре справки и поддержки, в "http://go.microsoft.com/fwlink/events.asp". причем пинг по имени проходит нормально. пользователи автаризируются без проблем. у меня такое предположение что это все из-за доменного имени local.istok.net вместо положенного istok.local как можно решить проблему без переименовани DC? можно ли сделать копию только данных в АД, (политик группы пользователи) , а не system state который в моей ситуации не поможет? ой, извеняюсь Microsoft Windows [Версия 5.2.3790] (С) Корпорация Майкрософт, 1985-2003. C:\Documents and Settings\mafik>g:\dcdiag.exe Domain Controller Diagnosis Performing initial setup: Done gathering initial info. Doing initial required tests Testing server: Default-First-Site-Name\DC Starting test: Connectivity ......................... DC passed test Connectivity Doing primary tests Testing server: Default-First-Site-Name\DC Starting test: Replications ......................... DC passed test Replications Starting test: NCSecDesc ......................... DC passed test NCSecDesc Starting test: NetLogons ......................... DC passed test NetLogons Starting test: Advertising ......................... DC passed test Advertising Starting test: KnowsOfRoleHolders ......................... DC passed test KnowsOfRoleHolders Starting test: RidManager ......................... DC passed test RidManager Starting test: MachineAccount ......................... DC passed test MachineAccount Starting test: Services ......................... DC passed test Services Starting test: ObjectsReplicated ......................... DC passed test ObjectsReplicated Starting test: frssysvol ......................... DC passed test frssysvol Starting test: frsevent ......................... DC passed test frsevent Starting test: kccevent ......................... DC passed test kccevent Starting test: systemlog ......................... DC passed test systemlog Starting test: VerifyReferences ......................... DC passed test VerifyReferences Running partition tests on : ForestDnsZones Starting test: CrossRefValidation ......................... ForestDnsZones passed test CrossRefValidation Starting test: CheckSDRefDom ......................... ForestDnsZones passed test CheckSDRefDom Running partition tests on : DomainDnsZones Starting test: CrossRefValidation ......................... DomainDnsZones passed test CrossRefValidation Starting test: CheckSDRefDom ......................... DomainDnsZones passed test CheckSDRefDom Running partition tests on : Schema Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Running partition tests on : Configuration Starting test: CrossRefValidation ......................... Configuration passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDRefDom Running partition tests on : local Starting test: CrossRefValidation ......................... local passed test CrossRefValidation Starting test: CheckSDRefDom ......................... local passed test CheckSDRefDom Running enterprise tests on : local.istok.net Starting test: Intersite ......................... local.istok.net passed test Intersite Starting test: FsmoCheck ......................... local.istok.net passed test FsmoCheck C:\Documents and Settings\mafik> ================================================================= C:\Documents and Settings\mafik>g:\netdiag.exe ....................................... Computer Name: DC DNS Host Name: dc.local.istok.net System info : Windows 2000 Server (Build 3790) Processor : x86 Family 15 Model 67 Stepping 3, AuthenticAMD List of installed hotfixes : KB957097 KB958644 KB958687 Q147222 Netcard queries test . . . . . . . : Passed [WARNING] The net card 'VMware Virtual Ethernet Adapter for VMnet8' may not be working because it has not received any packets. [WARNING] The net card 'VMware Virtual Ethernet Adapter for VMnet1' may not be working because it has not received any packets. GetStats failed for '¦Ё*ьющ ярЁрыыхы№эvщ яюЁЄ'. [ERROR_NOT_SUPPORTED] [WARNING] The net card '¦шэшяюЁЄ WAN (PPTP)' may not be working because it h as not received any packets. [WARNING] The net card '¦шэшяюЁЄ WAN (PPPoE)' may not be working because it has not received any packets. [WARNING] The net card '¦шэшяюЁЄ WAN (IP)' may not be working because it has not received any packets. GetStats failed for '¦шэшяюЁЄ WAN (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : ¦юфъы¦ўхэшх яю ыюъры№эющ ёхЄш Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc IP Address . . . . . . . . : 192.168.10.3 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : 192.168.10.3 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. No remote names have been found. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Adapter : VMware Network Adapter VMnet1 Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc IP Address . . . . . . . . : 192.168.217.1 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. No remote names have been found. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Adapter : VMware Network Adapter VMnet8 Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc IP Address . . . . . . . . : 192.168.118.1 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : Dns Servers. . . . . . . . : AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. No remote names have been found. WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{6FC65342-2D8E-4976-AAFD-C9DCFD31D691} NetBT_Tcpip_{8C053946-7C97-4780-B06C-68796700B795} NetBT_Tcpip_{825E9C9D-00D8-427C-AF56-FBDD9815620D} 3 NetBt transports currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Failed [FATAL] NO GATEWAYS ARE REACHABLE. You have no connectivity to other network segments. If you configured the IP protocol manually then you need to add at least one valid gateway. NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Servi ce', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Failed [WARNING] Cannot find a primary authoritative DNS server for the name 'dc.local.istok.net.'. [ERROR_TIMEOUT] The name 'dc.local.istok.net.' may not be registered in DNS. [WARNING] Cannot find a primary authoritative DNS server for the name 'dc.local.istok.net.'. [ERROR_TIMEOUT] The name 'dc.local.istok.net.' may not be registered in DNS. [FATAL]: The DNS registration for 'dc.local.istok.net' is incorrec t on all DNS servers. PASS - All the DNS entries for DC are registered on DNS server '192.168.10.3 ' and other DCs also have some of the names registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{6FC65342-2D8E-4976-AAFD-C9DCFD31D691} NetBT_Tcpip_{8C053946-7C97-4780-B06C-68796700B795} NetBT_Tcpip_{825E9C9D-00D8-427C-AF56-FBDD9815620D} The redir is bound to 3 NetBt transports. List of NetBt transports currently bound to the browser NetBT_Tcpip_{6FC65342-2D8E-4976-AAFD-C9DCFD31D691} NetBT_Tcpip_{825E9C9D-00D8-427C-AF56-FBDD9815620D} NetBT_Tcpip_{8C053946-7C97-4780-B06C-68796700B795} The browser is bound to 3 NetBt transports. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Passed Service status is: Started Service startup is: Automatic IPSec service is available, but no policy is assigned or active Note: run "ipseccmd /?" for more detailed information The command completed successfully C:\Documents and Settings\mafik> ============================================================= C:\Documents and Settings\mafik>ipconfig -all Настройка протокола IP для Windows Имя компьютера . . . . . . . . . : dc Основной DNS-суффикс . . . . . . : local.istok.net Тип узла. . . . . . . . . . . . . : неизвестный IP-маршрутизация включена . . . . : нет WINS-прокси включен . . . . . . . : нет Порядок просмотра суффиксов DNS . : local.istok.net istok.net Подключение по локальной сети - Ethernet адаптер: DNS-суффикс этого подключения . . : Описание . . . . . . . . . . . . : NVIDIA nForce Networking Controller Физический адрес. . . . . . . . . : 00-1E-8C-0A-71-05 DHCP включен. . . . . . . . . . . : нет IP-адрес . . . . . . . . . . . . : 192.168.10.3 Маска подсети . . . . . . . . . . : 255.255.255.0 Основной шлюз . . . . . . . . . . : DNS-серверы . . . . . . . . . . . : 192.168.10.3 VMware Network Adapter VMnet8 - Ethernet адаптер: DNS-суффикс этого подключения . . : Описание . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet 8 Физический адрес. . . . . . . . . : 00-50-56-C0-00-08 DHCP включен. . . . . . . . . . . : нет IP-адрес . . . . . . . . . . . . : 192.168.118.1 Маска подсети . . . . . . . . . . : 255.255.255.0 Основной шлюз . . . . . . . . . . : VMware Network Adapter VMnet1 - Ethernet адаптер: DNS-суффикс этого подключения . . : Описание . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet 1 Физический адрес. . . . . . . . . : 00-50-56-C0-00-01 DHCP включен. . . . . . . . . . . : нет IP-адрес . . . . . . . . . . . . : 192.168.217.1 Маска подсети . . . . . . . . . . : 255.255.255.0 Основной шлюз . . . . . . . . . . : C:\Documents and Settings\mafik> \====================================================== C:\Documents and Settings\mafik>nslookup Default Server: dc.local.istok.net Address: 192.168.10.3 > dragon.local.istok.net Server: dc.local.istok.net Address: 192.168.10.3 DNS request timed out. timeout was 2 seconds. Name: dragon.local.istok.net Address: 192.168.10.12 > > altair.local.istok.net Server: dc.local.istok.net Address: 192.168.10.3 DNS request timed out. timeout was 2 seconds. Name: altair.local.istok.net Address: 192.168.10.14 ============================================================= на всех клиентах Тип события: Ошибка Источник события: Userenv Категория события: Отсутствует Код события: 1054 Дата: 17.02.2009 Время: 1:54:27 Пользователь: NT AUTHORITY\SYSTEM Компьютер: DC Описание: Не удалось получить имя контроллера домена в этой сети. (Непредвиденная сетевая ошибка. ). Обработка групповой политики прекращена. Дополнительные сведения можно найти в центре справки и поддержки, в "http://go.microsoft.com/fwlink/events.asp". |
Отправлено: 19:52, 18-02-2009 |
Ветеран Сообщения: 12417
Профиль | Отправить PM | Цитировать hnsk, тут искали?
------- Отправлено: 10:42, 19-02-2009 | #2 |
Профиль | Сайт | Отправить PM | Цитировать Пропишите шлюз и DNS на контроллере и выполните netdiag /fix
------- Отправлено: 17:28, 19-02-2009 | #3 |
Профиль | Отправить PM | Цитировать Oleg Krylov,
может это быть от того, что я назвал свой домен не по рекомендациям? exo, искал. микрософт рекомендует проверить правильность ввода ip dns'a. естественно и на сервер все введено вверно. кстати, я не уточнаял ошибки появляются не только на клиентах, но и на сервере тоже. |
Отправлено: 17:37, 22-02-2009 | #4 |
Цитата hnsk:
хм... вообщето там приличная статья, с использоваением реестра и прочего... |
------- Отправлено: 17:55, 22-02-2009 | #5 |
Профиль | Отправить PM | Цитировать exo, если вас не затруднит,то дайте ссылку.
желательно на русском. |
Отправлено: 18:04, 22-02-2009 | #6 |
Профиль | Отправить PM | Цитировать hnsk, упс... извиняюсь... ошибся в одной цыфре ошибки... 1058
------- Отправлено: 20:38, 22-02-2009 | #7 |
Профиль | Сайт | Отправить PM | Цитировать Цитата hnsk:
Цитата hnsk:
------- Отправлено: 21:41, 22-02-2009 | #8 |
Профиль | Отправить PM | Цитировать exo, спасибо! 1058 и 1030 тоже шли в комплекте. их я вылечил, а вот 1054 осталась.
странно. но папку sysvol доступна и групповые политики успешно обновляются. правда на некоторых машинах встречаются 1202. которые я лечил переименованием secedit.sdb. Oleg Krylov, Цитата Oleg Krylov:
Цитата Oleg Krylov:
то есть на клиентах и серверев поле шлюз мне нужно написать ip контроллера домена? подскажите пожалуйста, где можно почитать про взаимодействие dns и ad? и затем netdiag /fix? |
Последний раз редактировалось hnsk, 22-02-2009 в 23:14. Отправлено: 23:02, 22-02-2009 | #9 |
------- Отправлено: 00:41, 23-02-2009 | #10 |
| Проблеммы с DNS или с AD %) | zipanton | Microsoft Windows NT/2000/2003 | 5 | 25-04-2009 20:08 | |
| [решено] Проблема с DNS. | stlord | Microsoft Windows NT/2000/2003 | 11 | 14-11-2008 12:06 | |
| Ошибка при динамической регистрации или удалении одной или нескольких записей DNS | fesenus | Microsoft Windows NT/2000/2003 | 3 | 19-11-2007 11:36 | |
| [решено] Проблема с DNS на корне. | Butunin Klim | Microsoft Windows NT/2000/2003 | 4 | 11-09-2007 11:46 | |
| [решено] Проблема NAT'a или уже бог знает чего... (2003RU sp1, DC, DNS, NAT+10 XP ) | Solid20 | Microsoft Windows NT/2000/2003 | 14 | 24-07-2006 10:32 | |
