| Компьютерный форум OSzone.net » Linux и FreeBSD » Программное обеспечение Linux и FreeBSD » Проблема с настройкой Exim |
Новый участник Сообщения: 4 |
Добрый день.
Поставил exim, сетки нет. Помогите устранить проблему с настройкой локальных почтовых ящиков. При проверке email'a выдается следующее: linux:/ # /usr/exim/bin/exim -bt -d tux@localhost Exim version 4.71 uid=0 gid=0 pid=5586 D=fbb95cfd Berkeley DB: Sleepycat Software: Berkeley DB 4.3.27: (September 9, 2005) Support for: iconv() DKIM Lookups: lsearch wildlsearch nwildlsearch iplsearch dbm dbmnz dnsdb Authenticators: Routers: accept dnslookup ipliteral manualroute queryprogram redirect Transports: appendfile autoreply pipe smtp Fixed never_users: 0 Size of off_t: 8 changed uid/gid: forcing real = effective uid=0 gid=0 pid=5586 auxiliary group list: <none> seeking password data for user "root": cache not available getpwnam() succeeded uid=0 gid=0 configuration file is /usr/exim/configure log selectors = 00000ffc 00212001 trusted user admin user seeking password data for user "exim": cache not available getpwnam() succeeded uid=1003 gid=100 originator: uid=0 gid=0 login=root name=root sender address = root@linux Address testing: uid=0 gid=100 euid=0 egid=100 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Testing tux@localhost >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Considering tux@localhost >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> routing tux@localhost --------> dnslookup router <-------- local_part=tux domain=localhost checking domains localhost in "@"? no (end of list) localhost in "! +local_domains"? yes (end of list) calling dnslookup router dnslookup router called for tux@localhost domain = localhost DNS lookup of localhost (MX) gave TRY_AGAIN localhost in dns_again_means_nonexist? no (option unset) returning DNS_AGAIN dnslookup router: defer for tux@localhost message: host lookup did not complete tux@localhost cannot be resolved at this time: host lookup did not complete search_tidyup called >>>>>>>>>>>>>>>> Exim pid=5586 terminating with rc=1 >>>>>>>>>>>>>>>> |
Отправлено: 17:49, 03-03-2010 |
Старожил Сообщения: 398
Профиль | Отправить PM | Цитировать Цитата saimoz:
------- Отправлено: 08:29, 04-03-2010 | #2 |
Профиль | Отправить PM | Цитировать Может быть, это из-за следующего:
linux:~ # host locahost ;; connection timed out; no servers could be reached А как тогда это лечить? У меня Suse 10.0 |
Отправлено: 16:12, 05-03-2010 | #3 |
| Медиа - Проблема с настройкой микрофона | hardi | Microsoft Windows 2000/XP | 2 | 10-08-2009 08:30 | |
| Интернет - Проблема с настройкой сети | Dav3000 | Microsoft Windows Vista | 7 | 19-04-2009 12:28 | |
| Проблема с настройкой микрофона.... | Bullet-Avalon | Хочу все знать | 3 | 08-01-2009 00:18 | |
| ALTLinux - Проблема с Exim | podtibok | Общий по Linux | 6 | 15-02-2008 15:38 | |
| Проблема с настройкой в Linux RH 7.3 | dante | Программное обеспечение Linux и FreeBSD | 12 | 16-08-2002 08:26 | |
