ExRCA is testing RPC/HTTP connectivity.
The RPC/HTTP test completed successfully.
Test Steps
Attempting to test Autodiscover for
[email protected]
Autodiscover was tested successfully.
Test Steps
ExRCA is attempting each method of contacting the Autodiscover service.
The Autodiscover service was tested successfully.
Test Steps
Attempting to test potential AutoDiscover URL
https://shaftsinkersrus.ru/AutoDisco...toDiscover.xml
Testing of this potential Autodiscover URL failed.
Test Steps
Attempting to resolve the host name shaftsinkersrus.ru in DNS.
The Host could not be resolved.
Tell me more about this issue and how to resolve it
Additional Details
Host shaftsinkersrus.ru could not be resolved in DNS Exception details:
Message: The requested name is valid, but no data of the requested type was found
Type: System.Net.Sockets.SocketException
Stack trace:
at System.Net.Dns.GetAddrInfo(String name)
at System.Net.Dns.InternalGetHostByName(String hostName, Boolean includeIPv6)
at System.Net.Dns.GetHostAddresses(String hostNameOrAddress)
at Microsoft.Exchange.Tools.ExRca.Tests.ResolveHostTest.PerformTestReally()
https://autodiscover.shaftsinkersrus...toDiscover.xml
Test Steps
Attempting to resolve the host name autodiscover.shaftsinkersrus.ru in DNS.
Host successfully resolved
Additional Details
IP(s) returned: 217.174.107.112
Testing TCP Port 443 on host autodiscover.shaftsinkersrus.ru to ensure it is listening and open.
The port was opened successfully.
ExRCA is testing the SSL certificate to make sure it's valid.
The SSL certificate failed one or more certificate validation checks.
Additional Details
A network error occurred while communicating with remote host
Exception details:
Message: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
Type: System.IO.IOException
Stack trace:
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)
at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost)
at Microsoft.Exchange.Tools.ExRca.Tests.SSLCertificateTest.PerformTestReally()
Exception details:
Stack trace:
ExRCA is attempting to contact the Autodiscover service using the HTTP redirect method.
The Autodiscover service was successfully contacted using the HTTP redirect method.
Test Steps
Additional Details
Testing TCP Port 80 on host autodiscover.shaftsinkersrus.ru to ensure it is listening and open.
Checking Host autodiscover.shaftsinkersrus.ru for an HTTP redirect to AutoDiscover
The redirect (HTTP 301/302) response was received successfully.
Additional Details
Redirect URL:
https://exch.unisync.ru/autodiscover...todiscover.xml
Testing of the Autodiscover URL was successful.
Test Steps
Attempting to resolve the host name exch.unisync.ru in DNS.
Additional Details
IP(s) returned: 217.174.107.111
Testing TCP Port 443 on host exch.unisync.ru to ensure it is listening and open.
The certificate passed all validation requirements.
Test Steps
The certificate name is being validated.
Successfully validated the certificate name
Additional Details
Found hostname exch.unisync.ru in Certificate Subject Common name
Certificate trust is being validated.
The certificate is trusted and all certificates are present in the chain.
Additional Details
The Certificate chain has be validated up to a trusted root. Root = CN=UTN - DATACorp SGC, OU=http://www.usertrust.com, O=The USERTRUST Network, L=Salt Lake City, S=UT, C=US
The certificate date is being confirmed to ensure the certificate is valid.
Date validation passed. The certificate hasn't expired.
Additional Details
Certificate is valid: NotBefore = 3/17/2010 12:00:00 AM, NotAfter = 3/17/2011 11:59:59 PM"
The IIS configuration is being checked for client certificate authentication.
Client certificate authentication wasn't detected.
Additional Details
Accept/Require Client Certificates not configured.
ExRCA is attempting to send an Autodiscover POST request to potential Autodiscover URLs.
Successfully Retrieved AutoDiscover Settings by sending AutoDiscover POST.
Test Steps
Attempting to Retrieve XML AutoDiscover Response from url
https://exch.unisync.ru/autodiscover...todiscover.xml for user
[email protected]
The Autodiscover XML response was successfully retrieved.
Additional Details
AutoDiscover Account Settings
XML Response:
<?xml version="1.0"?>
<Autodiscover xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://schemas.microsoft.com/exchange/autodiscover/responseschema/2006">
<Response xmlns="http://schemas.microsoft.com/exchange/autodiscover/outlook/responseschema/2006a">
<User>
<DisplayName>Крылов Леонид</DisplayName>
<LegacyDN>/o=First Organization/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)/cn=Recipients/cn=Krylovlf_shaft</LegacyDN>
<DeploymentId>5cb385cc-84dc-45f8-9f5c-2074c52bd2e8</DeploymentId>
</User>
<Account>
<AccountType>email</AccountType>
<Action>settings</Action>
<Protocol>
<Type>EXCH</Type>
<Server>EMail01.exch.zone</Server>
<ServerDN>/o=First Organization/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)/cn=Configuration/cn=Servers/cn=EMAIL01</ServerDN>
<ServerVersion>720180F0</ServerVersion>
<MdbDN>/o=First Organization/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)/cn=Configuration/cn=Servers/cn=EMAIL01/cn=Microsoft Private MDB</MdbDN>
<ASUrl>https://email01.exch.zone/EWS/Exchange.asmx</ASUrl>
<OOFUrl>https://email01.exch.zone/EWS/Exchange.asmx</OOFUrl>
<OABUrl>Public Folder</OABUrl>
<UMUrl>https://email01.exch.zone/UnifiedMessaging/Service.asmx</UMUrl>
<Port>0</Port>
<DirectoryPort>0</DirectoryPort>
<ReferralPort>0</ReferralPort>
<PublicFolderServer>EMail01.exch.zone</PublicFolderServer>
<AD>SQL01.exch.zone</AD>
<EwsUrl>https://email01.exch.zone/EWS/Exchange.asmx</EwsUrl>
</Protocol>
<Protocol>
<Type>EXPR</Type>
<Server>exch.unisync.ru</Server>
<ASUrl>https://exch.unisync.ru/EWS/Exchange.asmx</ASUrl>
<OOFUrl>https://exch.unisync.ru/EWS/Exchange.asmx</OOFUrl>
<Port>0</Port>
<SSL>On</SSL>
<AuthPackage>Basic</AuthPackage>
<EwsUrl>https://exch.unisync.ru/EWS/Exchange.asmx</EwsUrl>
</Protocol>
<Protocol>
<Type>WEB</Type>
<Port>0</Port>
<Internal>
<OWAUrl AuthenticationMethod="Basic, Fba">https://email01.exch.zone/owa</OWAUrl>
<Protocol>
<Type>EXCH</Type>
</Protocol>
</Internal>
</Protocol>
</Account>
</Response>
</Autodiscover>
Autodiscover settings for Outlook Anywhere are being validated.
Outlook Anywhere Autodiscover Settings validated
Additional Details
Test Steps
Additional Details
Additional Details
Additional Details
Additional Details
Testing Http Authentication Methods for URL
https://exch.unisync.ru/rpc/rpcproxy.dll
The HTTP authentication methods are correct.
Additional Details
Found all expected authentication methods and no disallowed methods. Methods Found: Basic
SSL mutual authentication with the RPC proxy server is being tested.
Mutual authentication was verified successfully.
Additional Details
Certificate common name exch.unisync.ru matches msstd:exch.unisync.ru
Attempting to Ping RPC Proxy exch.unisync.ru
RPC Proxy was pinged successfully.
Additional Details
Completed with HTTP status 200 - OK
Attempting to ping RPC Endpoint 6001 (Exchange Information Store) on server EMail01.exch.zone
Pinged Endpoint successfully
Additional Details
RPC Status Ok (0) returned in 493 ms.
ExRCA is testing the Name Service Provider Interface (NSPI) on the Exchange Mailbox server.
Successfully tested NSPI Interface.
Test Steps
Attempting to ping RPC Endpoint 6004 (NSPI Proxy Interface) on server EMail01.exch.zone
Additional Details
RPC Status Ok (0) returned in 24 ms.
Testing NSPI "Check Name" for user
[email protected] against server EMail01.exch.zone
Check Name succeeded.
Additional Details
DisplayName: Krylovlf_shaft, LegDN: /o=First Organization/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)/cn=Recipients/cn=Krylovlf_shaft
ExRCA is testing the Referral service on the Exchange Mailbox server.
The Referral service was tested successfully.
Test Steps
Attempting to ping RPC Endpoint 6002 (Referral Interface) on server EMail01.exch.zone
Additional Details
RPC Status Ok (0) returned in 415 ms.
Attempting to perform Referral for user /o=First Organization/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)/cn=Recipients/cn=Krylovlf_shaft on Server EMail01.exch.zone
Succeeded getting Referral
Additional Details
Server returned by Referral Service: EMail01.exch.zone
ExRCA is testing the Exchange Information Store on the Mailbox server.
Successfully tested the Information Store
Test Steps
Additional Details
RPC Status Ok (0) returned in 187 ms.
Testing Logon to the Exchange Information Store
Successfully logged on to the Information Store
