| Компьютерный форум OSzone.net » Серверные продукты Microsoft » ISA Server / Microsoft Forefront TMG » Настройка utorren для TMG + FWC |
Пользователь Сообщения: 101 |
Всем привет!
Руководствуясь всеизвестными правилами настроил TMG на работу с торрентами: 1) Set up the following new Protocols: Name: BitTorrent (Inbound) Ports: TCP - 64000 to 64100 Inbound Secondary connection: TCP 64000 - 64100 Outbound Name: BitTorrent (Outbound) Ports: TCP - 64000 to 64100 Outbound Secondary connection: TCP 64000 - 64100 Inbound Name BitTorrent (UDP) Ports: 64000 to 64100 Send Receive Secondary connection: 64100 to 64100 Send Receive You can add each of these to the same Access Rule. Создал правило доступа, из внутренне к внешней по вышеуказанным портам) Create another new Protocol on a per-client basis: Name: BitTorrent (Server - <Client Name>) Ports: Create a TCP Inbound port range somewhere between 64000 and 64100 (e.g. 64000 to 64010) Create a Non-Web Server Protocol Publishing Rule per BitTorrent client (client machines must have static IP or have DHCP reservations). These rules are the same thing as SOHO router's "port forwarding": Name: What ever you want, be descriptive as to what the client using this rule is Server IP: The client running BitTorrent Listen from: External (aka The Internet) Edit the above Server Publishing rule and go to the To tab. Make sure the radio box "Requests appear to come from the original client" is ticked. Создал правило не вебсервера, от клиента к внешней по вышеуказанным портам) Go to Configuration -> General -> Define Firewall Client Settings -> Application Settings tab Create two New Applications: Application: [Executable name without file extension, e.g. utorrent] Key: RemoteBindUdpPorts Value: 64000-64100 Application: [Executable name without file extension, e.g. utorrent] Key: ServerBindTcpPorts Value: 64000-64100 Save all of the above changes and commit them to the ISA Server. Создал правило доступа для FWC) Open utorrent, go to Options -> Preferences -> Connection, set the/a port that your Server Publishing Rule is using. Under Advanced, go to net.outgoing_port and set it between 64000 and 64100. Указал порт в utorrent клиенте) I've also set the IP/host name to report to tracker to a Dyndns hostname, though you can also use the ISA Server's external IP (if you're running ISA in Edge firewall mode). Note: I have not gotten DHT to function in my limited tests (sits at Waiting to log in or login with 0 nodes), but uTorrent reports that NAT is functioning correctly. Download speeds are excellent and upload also works. Also note that these same steps should be applicable to ISA 2004, but NOT ISA 2000. И не работает... |
Отправлено: 11:45, 10-11-2011 |
Ветеран Сообщения: 4677
Профиль | Отправить PM | Цитировать Цитата Agnicul:
new protocol: %name_inbound% - TCP inbound - %порт_указанный_в_клиенте%. %name_outbound% - TCP outbound - %порт_указанный_в_клиенте%. БЕЗ дополнительного чего-то либо. Publish non-web server protocols: %name% - IP хоста с клиентом - свежесозданный протокол - next FW Policy: Allow - %name_outbound% - internal - External - all users Apply Цитата Agnicul:
------- Отправлено: 11:59, 10-11-2011 | #2 |
| FWC - автообнаружение ISA Server 2006 | VV_Ekb | ISA Server / Microsoft Forefront TMG | 10 | 08-11-2011 14:30 | |
| [решено] Настройка VPN, шлюза Интернет и локальной сети на TMG | Qbok | ISA Server / Microsoft Forefront TMG | 1 | 20-04-2011 20:08 | |
| [решено] Настройка Outlook через Forefront tmg | HappySmiley | ISA Server / Microsoft Forefront TMG | 7 | 11-04-2011 12:34 | |
| [решено] Forefront TMG и настройка почтового клиента под GMAIL | whitekmv | ISA Server / Microsoft Forefront TMG | 41 | 25-05-2010 17:35 | |
| Интернет - MS ISA Server 2004 + FWC | dim_alf | Программное обеспечение Windows | 2 | 07-10-2008 16:45 | |
