| Компьютерный форум OSzone.net » Linux и FreeBSD » Новости и флейм из мира *nix » squashfs-tools |
squashfs-tools
Пользователь Сообщения: 144 |
Добрый день!
Пытаюсь распоковать архив squashfs с помощью squashfs_tools-4.0-i686-cygwin, утилита выдает ошибки при распаковки. Кто-нибудь в курсе и-за чего?: C:\1>unsquashfs.exe C:\1\initrd cygwin warning: MS-DOS style path detected: C:\1\initrd Preferred POSIX equivalent is: /1/initrd CYGWIN environment variable option "nodosfilewarning" turns off this warning. Consult the user's guide for more details about POSIX paths: http://cygwin.com/cygwin-ug-net/usin...sing-pathnames Parallel unsquashfs: Using 2 processors 393 inodes (543 blocks) to write [=======================================/ ] 151/543 27% create_inode: could not create character device squashfs-root/dev/agpgart, because you're not superuser! create_inode: could not create character device squashfs-root/dev/console, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/tty0, because you're not superuser! create_inode: could not create character device squashfs-root/dev/tty1, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/tty2, because you're not superuser! create_inode: could not create character device squashfs-root/dev/tty3, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/tty4, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/tty5, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/tty6, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/tty7, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/ttyS0, because you're not superuser! create_inode: could not create character device squashfs-root/dev/ttyS1, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/ttyS2, because you're not superuser! [========================================/ ] 152/543 27% create_inode: could not create character device squashfs-root/dev/ttyS3, because you're not superuser! [==================================================================================================== =======================================/ ] 529/543 97% created 268 files created 50 directories created 111 symlinks created 0 devices created 0 fifos C:\1> |
Отправлено: 14:21, 14-11-2011 |
Линуксоид-стакановец Сообщения: 2391
Профиль | Отправить PM | Цитировать Вам нужно получить права суперпользователя. Попробуйте запустить squashfs_tools-4.0-i686-cygwin от имени администратора.
------- Отправлено: 09:28, 23-11-2011 | #2 |
Профиль | Отправить PM | Цитировать В винде не получилось, только в lunix: sudo unsquashfs initrd
Отправлено: 10:34, 05-12-2011 | #3 |
| Утилиты - Distr Tools 1.4 | Shym | Наборы обновлений для Windows XP/2003/Windows 7 | 191 | 22-07-2014 07:22 | |
| CD и DVD - Daemon Tools | username | Программное обеспечение Windows | 120 | 02-05-2013 16:39 | |
| Архиваторы - [addon] 7z SFX tools stable/7z SFX tools beta | greg_b | Наборы обновлений для Windows XP/2003/Windows 7 | 173 | 14-09-2012 19:30 | |
| XP Tools 9.8.23 | OSZone Software | Новости программного обеспечения | 0 | 28-09-2010 11:30 | |
| Прочие - SquashFS | CyberDaemon | Программное обеспечение Windows | 3 | 27-12-2009 00:05 | |
