| Компьютерный форум OSzone.net » Сфера Microsoft » Программное обеспечение Windows » Графика - ACEEventLogSource вымораживает мозг. |
Старожил Сообщения: 166 |
ATIACELog выдает уведомления пачками, постоянно по типу таких. В чем причина и как исправить? Не просто Лог убить через реестр, а убрать сам факт их появления? WinXP SP3
0000000070: 2013-05-14 02:47:13:640 No localization info found for CLI.Component.Dashboard.ATI.ACE.CLI.Component.Dashboard.TreePanel Error Called by: ATI.ACE.ResourceManagement.Foundation.Implementation.ResourceManagerImplementation::ApplyResourcesTo Control processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(ResourceManagement.Foundation.Implementation, Version=2.0.4567.41264, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------ 0000000071: 2013-05-14 02:47:13:875 No localization info found for CLI.Component.Dashboard.ATI.ACE.CLI.Component.Dashboard.TreePanel Error Called by: ATI.ACE.ResourceManagement.Foundation.Implementation.ResourceManagerImplementation::ApplyResourcesTo Control processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(ResourceManagement.Foundation.Implementation, Version=2.0.4567.41264, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------ 0000000072: 2013-05-14 02:47:13:875 No localization info found for CLI.Component.Dashboard.ATI.ACE.CLI.Component.Dashboard.TreePanel Error Called by: ATI.ACE.ResourceManagement.Foundation.Implementation.ResourceManagerImplementation::ApplyResourcesTo Control processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(ResourceManagement.Foundation.Implementation, Version=2.0.4567.41264, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------ 0000000073: 2013-05-14 02:47:28:906 RT_MMVideo::SetColorSettingsToDriver return= 10485765 Error Called by: ATI.ACE.CLI.Aspect.MMVideo.Graphics.Runtime.RT_MMVideo::SetColorSettingsToDriver processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(CLI.Aspect.MMVideo.Graphics.Runtime, Version=2.0.4567.41184, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------ 0000000074: 2013-05-14 02:47:29:109 Removing errant RevertAfterComponentUpdated observers. Error Called by: ATI.ACE.CLI.Component.Dashboard.DashboardForm::DashboardForm_Closing processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(CLI.Component.Dashboard, Version=2.0.4567.41139, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------ 0000000075: 2013-05-14 02:47:29:109 Target: ATI.ACE.CLI.Aspect.DeviceDFP.Graphics.Dashboard.DB_DeviceDFP Method: ATI.ACE.CLI.Aspect.DeviceDFP.Graphics.Dashboard.DB_DeviceDFP Error Called by: ATI.ACE.CLI.Component.Dashboard.DashboardForm::DashboardForm_Closing processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(CLI.Component.Dashboard, Version=2.0.4567.41139, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------0000000076: 2013-05-14 02:47:29:109 Target: ATI.ACE.CLI.Aspect.DeviceDFP.Graphics.Dashboard.DB_DeviceDFP Method: ATI.ACE.CLI.Aspect.DeviceDFP.Graphics.Dashboard.DB_DeviceDFP Error Called by: ATI.ACE.CLI.Component.Dashboard.DashboardForm::DashboardForm_Closing processID:00688 threadID:(CCCThreadNew:Dashboard) domainName:(ccc.exe ) assemblyName:(CLI.Component.Dashboard, Version=2.0.4567.41139, Culture=neutral, PublicKeyToken=90ba9c70f846762e) ------------------------------------------------------------------------------------------------------------------------ |
Отправлено: 02:59, 14-05-2013 |
Профиль | Отправить PM | Цитировать RADEON73, можно переустановить .NET Framework и AMD Catalyst (вместе с Control Center).
Отправлено: 07:42, 14-05-2013 | #2 |
Ветеран Сообщения: 1609
RADEON73, устанавливайте локализованную версию (русскую) ССС на локализованную версию ОС WinXP (русскую) и переустановите .NET Framework 2.0 SP2, включенный в состав пакета драйверов AMD Catalyst для Windows XP.
------- Отправлено: 10:56, 14-05-2013 | #3 |
Профиль | Отправить PM | Цитировать Мультиязычная версия ССС идущая в комплекте с единственно возможными драйверами ATICATALYST 12-6-legacy_xp32_dd_ccc_whql (agp hotfix) под карту RADEON HD3850 AGP. И Framework напрямую установленный через центр обновления microsoft, я уж не знаю где более локализованные версии брать
Но я попробую найти то что вы сказали. |
------- Отправлено: 15:08, 14-05-2013 | #4 |
Цитата RADEON73:
У вас ССС загружается при загрузке ПК? Удалите старую версию драйвера с помощью Диспертчера установки Catalyst, перезагрузитесь и установите новую версию. |
------- Последний раз редактировалось Petunchicus, 14-05-2013 в 15:38. Отправлено: 15:30, 14-05-2013 | #5 |
Профиль | Отправить PM | Цитировать Потому что AGP линейка видеокарт требует своего особого драйвера, я и читал про это, и пробовал ставить последние драйвера - отказывает (несовместимость оборудования), и сам сайт амд предлагает именно эти драйвера. Всякие левые прогри неправильно идентифицируют карту и пытаются подсунуть какие то левые но версией те же что вы сказали 13.1 , но они не подходят. ССС загружается все ок. Это просто уведомления а не критические ошибки. Может это потому чт одрайвер я сразу поставил, а каталист накатил уже поверх установленных Фреймворков, попробую установить как вы сказали. Результат напишу.
1) Драйвера обновились проблема осталась... Пробую переустановку в другой последовательности. |
------- Последний раз редактировалось RADEON73, 14-05-2013 в 16:09. Отправлено: 15:55, 14-05-2013 | #6 |
Цитата RADEON73:
Откройте ССС и в меню "Настройка" снимите галку с "Включить меню панели задач". Дальше в оснастке Службы (Управление компьютером)остановите (если запущена) службу Ati Hotkey poller и установите тип запуска вручную. Далее скачайте и установите Autoruns. Откройте утилиту и во вкладке Everything найдите строку StartCCC и удалите ее (выделите ПКМ и удалить). Перезагрузите ПК и проверьте журналы Windows. Цитата RADEON73:
------- Отправлено: 17:35, 14-05-2013 | #7 |
Профиль | Отправить PM | Цитировать Нет установка с нуля не помогла (А именно удалил VC++ все, удалил весь фраймворк,драйвера, почистил хвосты, поставил VC+ из распакованных файлов и Framework 2 оттуда же он установил сам + все нужные приложения), сразу после установки он первым делом пожаловался на отсутствие XML файла(1 ошибка), видимо это идиотище сам не копирует, а потом сам найти не может, ну и потом классически начал выдавать пачки вместе с запуском процесса, вот я стартовый лог сохранил, на любой вкус. А отключить не вариант, во первых одна ошибка примерно выдается вместе с загрузкой даже при выключенном ССС (из вашего сообщения выше), а остальные выдаются вместе с запуском.
Последний раз редактировалось RADEON73, 13-08-2015 в 19:15. Отправлено: 04:42, 15-05-2013 | #8 |
RADEON73,
Цитата RADEON73:
Согласен, установщик CIM работает плохо, причем на всех версиях Windows. Ваш ССС встал криво, многих элементов меню нет. Отсутствуют и некоторые параметры настройки видео. У вас есть дистрибутив Win XP SP3? |
------- Последний раз редактировалось Petunchicus, 18-06-2013 в 18:39. Отправлено: 10:56, 15-05-2013 | #9 |
Профиль | Отправить PM | Цитировать Оригинального нет, система накатом СП3 от XP сп2 устанавливалась. Переустановку другой версии я делать не буду ради уведомлений, проще убить всю аппартную часть ССС кроме драйвера, особо функции ССС я не использую кроме 3D да и производительность не ключевой элемент, я уж думаю стереть все к чертовой бабушке
------- Отправлено: 14:39, 15-05-2013 | #10 |
| Компьютер выносит мозг!?(( | Fox87 | Материнские платы и память | 14 | 15-05-2013 15:20 | |
| EventID - Код: 0 Источник: ACEEventLogSource | VSerge | Устранение критических ошибок Windows | 41 | 22-04-2013 08:53 | |
| Драйвер - ACEEventLogSource | Nik_p | Microsoft Windows 7 | 0 | 01-05-2012 20:46 | |
| IBM смогла смоделировать мозг кошки | OSZone News | Новости информационных технологий | 8 | 20-11-2009 10:17 | |
