| Компьютерный форум OSzone.net » Клиентские ОС Microsoft » Microsoft Windows 7 » Службы - [решено] Не работают некоторые службы |
Новый участник Сообщения: 34 |
Здравствуйте.
Моя проблема в том, что не работают такие службы как: SMB 2.0 MiniRedirector SMB 1.x MiniRedirector SMB MiniRedirector Wrapper and Engine Computer Browser Workstation Server. Заметил я эту проблему, когда просматривал Event Viewer. Несколько ошибок Error под номерами 7001, 7000, 7003 Error 7001 "The SMB 2.0 MiniRedirector service depends on the SMB MiniRedirector Wrapper and Engine service which failed to start because of the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it." Error 7001 "The SMB 1.x MiniRedirector service depends on the SMB MiniRedirector Wrapper and Engine service which failed to start because of the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it." Error 7001 "The SMB MiniRedirector Wrapper and Engine service failed to start due to the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it." Error 7001 "The Server service depends on the Server SMB 1.xxx Driver service which failed to start because of the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it." Error 7001 "The Computer Browser service depends on the Workstation service which failed to start because of the following error: The dependency service does not exist or has been marked for deletion." Error 7000 "The Server SMB 1.xxx Driver service failed to start due to the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it." Error 7003 "The Workstation service depends the following service: Bowser. This service might not be installed." sfc /scannow не помогло. Что может быть причиной? Пожалуйста помогите. Моя операционная система Windows 7 Ultimate x86 EN |
Отправлено: 19:55, 10-12-2015 |
Ветеран Сообщения: 5380
Профиль | Отправить PM | Цитировать dionis_dvalishvili,
Пробовали заменять файл bowser.sys с ОС, где все работает, в папках: C:\Windows\System32\Drivers\ C:\Windows\WinSxS\amd64_microsoft-windows-bowser_31bf3856ad364e35_6.0.6002.18407_none_846ba9afd9bdf564\ Computer Browser service |
------- Отправлено: 20:09, 10-12-2015 | #2 |
Профиль | Отправить PM | Цитировать Спасибо за внимание Казбек
Сделал как вы посоветовали. Заменил свой файл bowser.sys в папке таким же файлом с другой ОС. Всё по прежнему - службы не запускаются А вот папка C:\Windows\WinSxS\amd64_microsoft-windows-bowser_31bf3856ad364e35_6.0.6002.18407_none_846ba9afd9bdf564\ Если должна быть, то наверно удалена? Или в моей версии Windows её вообще нет? При попытке запуска Browser и Workstation выскакивают соответственно окна сообщающие о том, что зависимые службы не работают. Вот так, ничего не получается. |
Отправлено: 13:38, 12-12-2015 | #3 |
Отправлено: 10:38, 13-12-2015 | #4 |
Профиль | Отправить PM | Цитировать Здравствуйте Petya V4sechkin
надеюсь правильно сделал:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Dionis>sc qc mrxsmb20
[SC] QueryServiceConfig SUCCESS
SERVICE_NAME: mrxsmb20
TYPE : 2 FILE_SYSTEM_DRIVER
START_TYPE : 2 AUTO_START
ERROR_CONTROL : 1 NORMAL
BINARY_PATH_NAME : system32\DRIVERS\mrxsmb20.sys
LOAD_ORDER_GROUP : Network
TAG : 7
DISPLAY_NAME : SMB 2.0 MiniRedirector
DEPENDENCIES : mrxsmb
SERVICE_START_NAME :
C:\Users\Dionis>sc query mrxsmb20
STATE : 1 STOPPED
WIN32_EXIT_CODE : 1068 (0x42c)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
C:\Users\Dionis>sc qc mrxsmb10
SERVICE_NAME: mrxsmb10
BINARY_PATH_NAME : system32\DRIVERS\mrxsmb10.sys
TAG : 6
DISPLAY_NAME : SMB 1.x MiniRedirector
C:\Users\Dionis>sc query mrxsmb10
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
BINARY_PATH_NAME : system32\DRIVERS\mrxsmb.sys
TAG : 5
DISPLAY_NAME : SMB MiniRedirector Wrapper and Engine
DEPENDENCIES : rdbss
STATE : 1 STOPPED
WIN32_EXIT_CODE : 1058 (0x422)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
C:\Users\Dionis>sc qc rdbss
SERVICE_NAME: rdbss
START_TYPE : 1 SYSTEM_START
BINARY_PATH_NAME : system32\DRIVERS\rdbss.sys
TAG : 4
DISPLAY_NAME : Redirected Buffering Sub Sysytem
DEPENDENCIES : Mup
C:\Users\Dionis>sc query rdbss
SERVICE_NAME: rdbss
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHU
WIN32_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
C:\Users\Dionis>sc qc Mup
SERVICE_NAME: Mup
START_TYPE : 0 BOOT_START
BINARY_PATH_NAME : \SystemRoot\System32\Drivers\mup.sys
TAG : 0
DISPLAY_NAME : Mup
DEPENDENCIES :
C:\Users\Dionis>sc query Mup
SERVICE_NAME: Mup
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
C:\Users\Dionis>sc qc bowser
[SC] OpenService FAILED 1060:
The specified service does not exist as an installed service.
C:\Users\Dionis>sc query bowser
[SC] EnumQueryServicesStatus:OpenService FAILED 1060:
Отправлено: 19:08, 13-12-2015 | #5 |
Профиль | Отправить PM | Цитировать dionis_dvalishvili, примените твик реестра
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\bowser] "DisplayName"="@%systemroot%\\system32\\browser.dll,-102" "Group"="Network" "ImagePath"=hex(2):73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,44,00,\ 52,00,49,00,56,00,45,00,52,00,53,00,5c,00,62,00,6f,00,77,00,73,00,65,00,72,\ 00,2e,00,73,00,79,00,73,00,00,00 "Description"="@%systemroot%\\system32\\browser.dll,-103" "ErrorControl"=dword:00000001 "Start"=dword:00000003 "Tag"=dword:00000005 "Type"=dword:00000002 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\mrxsmb] "Start"=dword:00000003 "Type"=dword:00000002 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\mrxsmb10] "Start"=dword:00000003 "Type"=dword:00000002 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\mrxsmb20] "Start"=dword:00000003 "Type"=dword:00000002 Затем выложите снова: |
Отправлено: 22:02, 13-12-2015 | #6 |
Профиль | Отправить PM | Цитировать Petya V4sechkin
START_TYPE : 3 DEMAND_START
TAG : 7
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
TAG : 6
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
TAG : 5
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Users\Dionis>
SERVICE_NAME: bowser
BINARY_PATH_NAME : system32\DRIVERS\bowser.sys
TAG : 5
DISPLAY_NAME : Browser Support Driver
DEPENDENCIES :
STATE : 1 STOPPED
WIN32_EXIT_CODE : 193 (0xc1)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Отправлено: 18:57, 14-12-2015 | #7 |
Профиль | Отправить PM | Цитировать Цитата dionis_dvalishvili:
В командной строке (cmd.exe) от имени Администратора выполните: Перезагрузитесь и выложите лог \Windows\Logs\CBS\CBS.log в архиве. |
Отправлено: 19:06, 14-12-2015 | #8 |
Отправлено: 12:34, 15-12-2015 | #9 |
Профиль | Отправить PM | Цитировать dionis_dvalishvili, файл C:\Windows\System32\drivers\bowser.sys по-прежнему поврежден.
Можете взять из дистрибутива: Извлечение файлов Windows 7 из дистрибутива |
Отправлено: 18:51, 15-12-2015 | #10 |
| Разное - Компьютер на Windows 8.1 зависает , но некоторые службы и возможности работают. | Hospitaller | Microsoft Windows 8 и 8.1 | 1 | 08-11-2014 08:48 | |
| Службы - [решено] Не удается запустить некоторые службы. | sheridan23 | Microsoft Windows 7 | 8 | 11-05-2013 16:01 | |
| Интернет - Не работают некоторые сайты!!! | Надежда0311 | Microsoft Windows 2000/XP | 4 | 18-03-2010 20:33 | |
| Службы - Некоторые службы не установились | BonaAnton | Microsoft Windows 2000/XP | 4 | 16-02-2010 01:17 | |
| Не работают некоторые клавиши | Carrera | Ноутбуки | 2 | 11-12-2009 08:11 | |
