| Компьютерный форум OSzone.net » Компьютеры + Интернет » Хочу все знать » Антидетект VPS/VDS |
Антидетект VPS/VDS
Новый участник Сообщения: 43 |
Привет, есть дедик (VPS/VDS). И мне надо обойти антидетект одной программы. Операционка стоит Windows 10 pro
Сканирование через Pafish выдает: Pafish
* Pafish (Paranoid fish) *
Some anti(debugger/VM/sandbox) tricks
used by malware for the general public.
[*] Windows version: 6.2 build 9200[*] CPU: GenuineIntel
Hypervisor: Microsoft Hv
CPU brand: Intel(R) Xeon(R) Platinum 8171M CPU @ 2.60GHz
[-] Debuggers detection[*] Using IsDebuggerPresent() ... OK
[-] CPU information based detections[*] Checking the difference between CPU timestamp counters (rdtsc) ... OK[*] Checking the difference between CPU timestamp counters (rdtsc) forcing VM exit ... traced![*] Checking hypervisor bit in cpuid feature bits ... traced![*] Checking cpuid hypervisor vendor for known VM vendors ... traced!
[-] Generic sandbox detection[*] Using mouse activity ... OK[*] Checking username ... OK[*] Checking file path ... OK[*] Checking common sample names in drives root ... OK[*] Checking if disk size <= 60GB via DeviceIoControl() ... OK[*] Checking if disk size <= 60GB via GetDiskFreeSpaceExA() ... OK[*] Checking if Sleep() is patched using GetTickCount() ... OK[*] Checking if NumberOfProcessors is < 2 via raw access ... OK[*] Checking if NumberOfProcessors is < 2 via GetSystemInfo() ... OK[*] Checking if pysical memory is < 1Gb ... OK[*] Checking operating system uptime using GetTickCount() ... OK[*] Checking if operating system IsNativeVhdBoot() ... OK
[-] Hooks detection[*] Checking function ShellExecuteExW method 1 ... OK[*] Checking function CreateProcessA method 1 ... OK
[-] Sandboxie detection[*] Using GetModuleHandle(sbiedll.dll) ... OK
[-] Wine detection[*] Using GetProcAddress(wine_get_unix_file_name) from kernel32.dll ... OK[*] Reg key (HKCU\SOFTWARE\Wine) ... OK
[-] VirtualBox detection[*] Scsi port->bus->target id->logical unit id-> 0 identifier ... OK[*] Reg key (HKLM\HARDWARE\Description\System "SystemBiosVersion") ... OK[*] Reg key (HKLM\SOFTWARE\Oracle\VirtualBox Guest Additions) ... OK[*] Reg key (HKLM\HARDWARE\Description\System "VideoBiosVersion") ... OK[*] Reg key (HKLM\HARDWARE\ACPI\DSDT\VBOX__) ... OK[*] Reg key (HKLM\HARDWARE\ACPI\FADT\VBOX__) ... OK[*] Reg key (HKLM\HARDWARE\ACPI\RSDT\VBOX__) ... OK[*] Reg key (HKLM\SYSTEM\ControlSet001\Services\VBox*) ... OK[*] Reg key (HKLM\HARDWARE\DESCRIPTION\System "SystemBiosDate") ... OK[*] Driver files in C:\WINDOWS\system32\drivers\VBox* ... OK[*] Additional system files ... OK[*] Looking for a MAC address starting with 08:00:27 ... OK[*] Looking for pseudo devices ... OK[*] Looking for VBoxTray windows ... OK[*] Looking for VBox network share ... OK[*] Looking for VBox processes (vboxservice.exe, vboxtray.exe) ... OK[*] Looking for VBox devices using WMI ... OK
[-] VMware detection[*] Scsi port 0,1,2 ->bus->target id->logical unit id-> 0 identifier ... OK[*] Reg key (HKLM\SOFTWARE\VMware, Inc.\VMware Tools) ... OK[*] Looking for C:\WINDOWS\system32\drivers\vmmouse.sys ... OK[*] Looking for C:\WINDOWS\system32\drivers\vmhgfs.sys ... OK[*] Looking for a MAC address starting with 00:05:69, 00:0C:29, 00:1C:14 or 00:50:56 ... OK[*] Looking for network adapter name ... OK[*] Looking for pseudo devices ... OK[*] Looking for VMware serial number ... OK
[-] Qemu detection[*] Scsi port->bus->target id->logical unit id-> 0 identifier ... OK[*] Reg key (HKLM\HARDWARE\Description\System "SystemBiosVersion") ... OK[*] cpuid CPU brand string 'QEMU Virtual CPU' ... OK
[-] Bochs detection[*] Reg key (HKLM\HARDWARE\Description\System "SystemBiosVersion") ... OK[*] cpuid AMD wrong value for processor name ... OK[*] cpuid Intel wrong value for processor name ... OK
[-] Cuckoo detection[*] Looking in the TLS for the hooks information structure ... OK
[-] Feel free to RE me, check log file for more information.
ошибки Pafish
Checking the difference between CPU timestamp counters (rdtsc) forcing VM exit ... traced! Checking hypervisor bit in cpuid feature bits ... traced! Checking cpuid hypervisor vendor for known VM vendors ... traced! Checking the difference between CPU timestamp counters (rdtsc) forcing VM exit ... traced! Checking the difference between CPU timestamp counters (rdtsc) forcing VM exit ... traced! Есть у кого-то варианты как решить данную проблему? |
Отправлено: 18:11, 05-05-2020 |
Забанен Сообщения: 6345
Зачем на виртуалке винда?
Отправлено: 20:06, 05-05-2020 | #2 |
Профиль | Отправить PM | Цитировать Мне не нужна еще одна винда на виртуалке. мне над обойти Антидетект. В программе Pafish выдает пробелы по пунктам которые я написал выше
Отправлено: 21:29, 05-05-2020 | #3 |
Ветеран Сообщения: 1594
Профиль | Отправить PM | Цитировать А что это за софтинка, которая хочет именно реальное железо?
------- Отправлено: 09:18, 06-05-2020 | #4 |
Пользователь Сообщения: 111
James Marsh, программы отказываются работать в виртуалке, например, в версии Lite вместо Pro. Или чтобы не отлаживали. Я встречался с этим в Total Uninstall. Да, много можно примеров привести, если поискать. Вирусы еще не любят виртуальное железо.
Отправлено: 23:17, 17-05-2020 | #5 |
| Прочее - VDS | LetoJizni | Общий по Linux | 2 | 15-06-2016 15:12 | |
| Сайт на VDS/VPS | Паркан | Вебмастеру | 1 | 27-07-2013 23:32 | |
| Прочее - Подскажите VDS сервис. | xctr | Сетевые технологии | 3 | 18-10-2011 19:28 | |
| VPS(VDS)+ прокси | lavrik2 | Хочу все знать | 3 | 26-07-2009 03:54 | |
| выбор VDS хостера | Vlad Drakula | Вебмастеру | 3 | 28-03-2008 20:26 | |
