| Компьютерный форум OSzone.net » Серверные продукты Microsoft » WSUS » [решено] в логах клиента 0x80244019 и 0x80190194 |
Старожил Сообщения: 473 |
Доброе время суток!!!
Уважаемые эксперты подскажите в чем проблема, вот что в логах проблемного клиента. 2010-06-09 14:28:22:192 1436 320 Misc =========== Logging initialized (build: 7.4.7600.226, tz: +0600) ===========
2010-06-09 14:28:22:192 1436 320 Misc = Process: C:\WINDOWS\system32\svchost.exe
2010-06-09 14:28:22:192 1436 320 Misc = Module: C:\WINDOWS\system32\wuaueng.dll
2010-06-09 14:28:22:192 1436 320 Service *************
2010-06-09 14:28:22:192 1436 320 Service ** START ** Service: Service startup
2010-06-09 14:28:22:209 1436 320 Agent * WU client version 7.4.7600.226
2010-06-09 14:28:22:209 1436 320 Agent * Base directory: C:\WINDOWS\SoftwareDistribution
2010-06-09 14:28:22:209 1436 320 Agent * Access type: Named proxy
2010-06-09 14:28:22:209 1436 320 Agent * Default proxy: proxy2.cbank.kz
2010-06-09 14:28:22:209 1436 320 Agent * Network state: Connected
2010-06-09 14:29:10:954 1436 320 Agent *********** Agent: Initializing Windows Update Agent ***********
2010-06-09 14:29:10:954 1436 320 Agent *********** Agent: Initializing global settings cache ***********
2010-06-09 14:29:10:954 1436 320 Agent * WSUS server: <NULL>
2010-06-09 14:29:10:954 1436 320 Agent * WSUS status server: <NULL>
2010-06-09 14:29:10:954 1436 320 Agent * Target group: Computers
2010-06-09 14:29:10:954 1436 320 Agent * Windows Update access disabled: No
2010-06-09 14:29:10:970 1436 320 DnldMgr Download manager restoring 0 downloads
2010-06-09 14:29:10:970 1436 320 AU ########### AU: Initializing Automatic Updates ###########
2010-06-09 14:29:10:986 1436 320 AU AU setting next sqm report timeout to 2010-06-09 08:29:10
2010-06-09 14:29:10:986 1436 320 AU # Approval type: Scheduled (User preference)
2010-06-09 14:29:10:986 1436 320 AU # Scheduled install day/time: Every day at 13:00
2010-06-09 14:29:10:986 1436 320 AU # Auto-install minor updates: Yes (User preference)
2010-06-09 14:29:10:986 1436 320 AU Setting AU scheduled install time to 2010-06-10 07:00:00
2010-06-09 14:29:10:986 1436 320 AU Initializing featured updates
2010-06-09 14:29:10:986 1436 320 AU Found 0 cached featured updates
2010-06-09 14:29:11:003 1436 320 AU AU finished delayed initialization
2010-06-09 14:29:11:814 1436 320 Report *********** Report: Initializing static reporting data ***********
2010-06-09 14:29:11:814 1436 320 Report * OS Version = 5.1.2600.3.0.65792
2010-06-09 14:29:11:943 1436 320 Report * Computer Brand = ECS
2010-06-09 14:29:11:943 1436 320 Report * Computer Model = P4M890T-M
2010-06-09 14:29:11:959 1436 320 Report * Bios Revision = 080013
2010-06-09 14:29:11:959 1436 320 Report * Bios Name = Default System BIOS
2010-06-09 14:29:11:959 1436 320 Report * Bios Release Date = 2006-10-05T00:00:00
2010-06-09 14:29:11:959 1436 320 Report * Locale ID = 1049
2010-06-09 14:30:44:106 1436 23c AU Triggering AU detection through DetectNow API
2010-06-09 14:30:44:106 1436 23c AU Triggering Online detection (non-interactive)
2010-06-09 14:30:44:106 1436 320 AU #############
2010-06-09 14:30:44:106 1436 320 AU ## START ## AU: Search for updates
2010-06-09 14:30:44:106 1436 320 AU <<## SUBMITTED ## AU: Search for updates [CallId = {A3DA1D7C-D68B-4F4E-ABD1-1F6CAB6E54D9}]
2010-06-09 14:30:44:106 1436 fd4 Agent *************
2010-06-09 14:30:44:106 1436 fd4 Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-06-09 14:30:44:106 1436 fd4 Agent * Online = Yes; Ignore download priority = No
2010-06-09 14:30:44:106 1436 fd4 Agent * Criteria = "IsHidden=0 and IsInstalled=0 and DeploymentAction='Installation' and IsAssigned=1 or IsHidden=0 and IsPresent=1 and DeploymentAction='Uninstallation' and IsAssigned=1 or IsHidden=0 and IsInstalled=1 and DeploymentAction='Installation' and IsAssigned=1 and RebootRequired=1 or IsHidden=0 and IsInstalled=0 and DeploymentAction='Uninstallation' and IsAssigned=1 and RebootRequired=1"
2010-06-09 14:30:44:106 1436 fd4 Agent * ServiceID = {9482F4B4-E343-43B6-B170-9A65BC822C77} Windows Update
2010-06-09 14:30:44:106 1436 fd4 Agent * Search Scope = {Machine}
2010-06-09 14:30:44:365 1436 fd4 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
2010-06-09 14:30:44:543 1436 fd4 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
2010-06-09 14:30:44:543 1436 fd4 Misc WARNING: DownloadFileInternal failed for http://download.windowsupdate.com/v9/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
2010-06-09 14:30:44:576 1436 fd4 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
2010-06-09 14:30:44:576 1436 fd4 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
2010-06-09 14:30:44:576 1436 fd4 Misc WARNING: DownloadFileInternal failed for http://download.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
2010-06-09 14:30:44:576 1436 fd4 Misc WARNING: DownloadFileInternal failed for http://www.update.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
2010-06-09 14:30:44:576 1436 fd4 Setup FATAL: IsUpdateRequired failed with error 0x80244019
2010-06-09 14:30:44:576 1436 fd4 Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed: 0x80244019
2010-06-09 14:30:44:576 1436 fd4 Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed, error = 0x80244019
2010-06-09 14:30:44:576 1436 fd4 Agent * WARNING: Skipping scan, self-update check returned 0x80244019
2010-06-09 14:30:44:592 1436 fd4 Agent * WARNING: Exit code = 0x80244019
2010-06-09 14:30:44:592 1436 fd4 Agent *********
2010-06-09 14:30:44:592 1436 fd4 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-06-09 14:30:44:592 1436 fd4 Agent *************
2010-06-09 14:30:44:592 1436 fd4 Agent WARNING: WU client failed Searching for update with error 0x80244019
2010-06-09 14:30:44:592 1436 e50 AU >>## RESUMED ## AU: Search for updates [CallId = {A3DA1D7C-D68B-4F4E-ABD1-1F6CAB6E54D9}]
2010-06-09 14:30:44:592 1436 e50 AU # WARNING: Search callback failed, result = 0x80244019
2010-06-09 14:30:44:592 1436 e50 AU # WARNING: Failed to find updates with error code 80244019
2010-06-09 14:30:44:592 1436 e50 AU #########
2010-06-09 14:30:44:592 1436 e50 AU ## END ## AU: Search for updates [CallId = {A3DA1D7C-D68B-4F4E-ABD1-1F6CAB6E54D9}]
2010-06-09 14:30:44:592 1436 e50 AU #############
2010-06-09 14:30:44:592 1436 e50 AU AU setting next detection timeout to 2010-06-09 13:30:44
2010-06-09 14:30:44:592 1436 e50 AU Setting AU scheduled install time to 2010-06-10 07:00:00
2010-06-09 14:30:49:765 1436 fd4 Report REPORT EVENT: {AC993E7C-7075-434C-9AF6-F271D1F15838} 2010-06-09 14:30:44:576+0600 1 148 101 {D67661EB-2423-451D-BF5D-13199E37DF28} 0 80244019 SelfUpdate Failure Software Synchronization Windows Update Client failed to detect with error 0x80244019.
2010-06-09 14:32:41:194 1436 320 Agent *********** Agent: Refreshing global settings cache ***********
2010-06-09 14:32:41:194 1436 320 Agent * WSUS server: http://fs (Changed)
2010-06-09 14:32:41:194 1436 320 Agent * WSUS status server: http://fs (Changed)
2010-06-09 14:32:41:194 1436 320 Agent * Target group: Computers (Unchanged)
2010-06-09 14:32:41:194 1436 320 Agent * Windows Update access disabled: No (Unchanged)
2010-06-09 14:32:41:194 1436 320 AU AU received policy change subscription event
2010-06-09 14:32:41:194 1436 320 AU Sus server changed through policy.
2010-06-09 14:32:41:194 1436 320 AU AU Options changed from policy.
2010-06-09 14:32:41:194 1436 320 AU ########### AU: Policy change processed ###########
2010-06-09 14:32:41:210 1436 320 AU # Policy changed, AU refresh required = No
2010-06-09 14:32:41:210 1436 320 AU # WSUS server: http://fs
2010-06-09 14:32:41:210 1436 320 AU # Detection frequency: 22
2010-06-09 14:32:41:210 1436 320 AU # Target group: Computers
2010-06-09 14:32:41:210 1436 320 AU # Approval type: Scheduled (Policy)
2010-06-09 14:32:41:210 1436 320 AU # Scheduled install day/time: Friday at 3:00
2010-06-09 14:32:41:226 1436 320 AU # Auto-install minor updates: Yes (Policy)
2010-06-09 14:32:41:226 1436 320 AU AU Refresh required....
2010-06-09 14:32:41:307 1436 320 AU AU setting next detection timeout to 2010-06-09 08:32:41
2010-06-09 14:32:41:307 1436 320 AU AU setting next sqm report timeout to 2010-06-09 08:32:41
2010-06-09 14:32:41:340 1436 320 AU AU setting next featured software notification timeout to 2010-06-09 08:32:41
2010-06-09 14:32:41:340 1436 320 AU Triggering Online detection (non-interactive)
2010-06-09 14:32:41:372 1436 320 AU #############
2010-06-09 14:32:41:372 1436 320 AU ## START ## AU: Search for updates
2010-06-09 14:32:41:388 1436 320 AU #########
2010-06-09 14:32:41:421 1436 320 AU <<## SUBMITTED ## AU: Search for updates [CallId = {FDC9AB8F-0C99-4321-BF9C-7B16FF31A559}]
2010-06-09 14:32:41:421 1436 fd4 Agent *************
2010-06-09 14:32:41:421 1436 fd4 Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-06-09 14:32:41:437 1436 fd4 Agent * Online = Yes; Ignore download priority = No
2010-06-09 14:32:41:437 1436 fd4 Agent * Criteria = "IsHidden=0 and IsInstalled=0 and DeploymentAction='Installation' and IsAssigned=1 or IsHidden=0 and IsPresent=1 and DeploymentAction='Uninstallation' and IsAssigned=1 or IsHidden=0 and IsInstalled=1 and DeploymentAction='Installation' and IsAssigned=1 and RebootRequired=1 or IsHidden=0 and IsInstalled=0 and DeploymentAction='Uninstallation' and IsAssigned=1 and RebootRequired=1"
2010-06-09 14:32:41:437 1436 fd4 Agent * ServiceID = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7} Managed
2010-06-09 14:32:41:437 1436 fd4 Agent * Search Scope = {Machine}
2010-06-09 14:32:41:486 1436 fd4 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
2010-06-09 14:32:41:486 1436 fd4 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
2010-06-09 14:32:41:486 1436 fd4 Misc WARNING: DownloadFileInternal failed for http://fs/selfupdate/wuident.cab: error 0x80190194
2010-06-09 14:32:41:486 1436 fd4 Setup FATAL: IsUpdateRequired failed with error 0x80244019
2010-06-09 14:32:41:486 1436 fd4 Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed: 0x80244019
2010-06-09 14:32:41:486 1436 fd4 Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed, error = 0x80244019
2010-06-09 14:32:41:486 1436 fd4 Agent * WARNING: Skipping scan, self-update check returned 0x80244019
2010-06-09 14:32:41:502 1436 fd4 Agent * WARNING: Exit code = 0x80244019
2010-06-09 14:32:41:502 1436 fd4 Agent *********
2010-06-09 14:32:41:502 1436 fd4 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-06-09 14:32:41:502 1436 fd4 Agent *************
2010-06-09 14:32:41:502 1436 fd4 Agent WARNING: WU client failed Searching for update with error 0x80244019
2010-06-09 14:32:41:502 1436 e50 AU >>## RESUMED ## AU: Search for updates [CallId = {FDC9AB8F-0C99-4321-BF9C-7B16FF31A559}]
2010-06-09 14:32:41:502 1436 e50 AU # WARNING: Search callback failed, result = 0x80244019
2010-06-09 14:32:41:502 1436 e50 AU # WARNING: Failed to find updates with error code 80244019
2010-06-09 14:32:41:502 1436 e50 AU #########
2010-06-09 14:32:41:518 1436 e50 AU ## END ## AU: Search for updates [CallId = {FDC9AB8F-0C99-4321-BF9C-7B16FF31A559}]
2010-06-09 14:32:41:518 1436 e50 AU #############
2010-06-09 14:32:41:518 1436 e50 AU AU setting next detection timeout to 2010-06-09 13:32:41
2010-06-09 14:32:41:518 1436 e50 AU Setting AU scheduled install time to 2010-06-10 21:00:00
2010-06-09 14:32:46:675 1436 fd4 Report REPORT EVENT: {9489EB27-58F5-4FD0-A90D-665AB4B1D158} 2010-06-09 14:32:41:486+0600 1 148 101 {D67661EB-2423-451D-BF5D-13199E37DF28} 0 80244019 SelfUpdate Failure Software Synchronization Windows Update Client failed to detect with error 0x80244019.
В HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU обнулил UseWUServer перегрузил, но изменений нет. ОС клиента XP SP3. Кто сталкивался с такой проблемой, подскажите как исправить эти ошибки? |
Отправлено: 13:20, 09-06-2010 |
Ветеран Сообщения: 4677
Профиль | Отправить PM | Цитировать ejik_off,
порт сервера указан у клиентов (80 или 8530, в зависимости от того как вы настраивали)? |
------- Отправлено: 13:39, 09-06-2010 | #2 |
Профиль | Отправить PM | Цитировать Цитата cameron:
Отправлено: 15:08, 09-06-2010 | #3 |
Профиль | Отправить PM | Цитировать Цитата ejik_off:
------- Отправлено: 15:13, 09-06-2010 | #4 |
Ветеран Сообщения: 3722
Профиль | Отправить PM | Цитировать Скачайте и запустите на клиенте WSUS Client Diagnostic Tool, результат покажите.
------- Отправлено: 15:48, 09-06-2010 | #5 |
Профиль | Отправить PM | Цитировать cameron,
Это тоже не помогло ![]() Telepuzik, Завтра скачаю и результаты выложу. |
Отправлено: 15:57, 09-06-2010 | #6 |
Профиль | Отправить PM | Цитировать Вывод команды proxycfg с проблемного клиента покажите.
------- Отправлено: 16:09, 09-06-2010 | #7 |
------- Отправлено: 16:10, 09-06-2010 | #8 |
Вот что дал proxycfg: C:\Documents and Settings\Gannur.NPFCAPITAL>proxycfg
Инструмент настройки прокси по умолчанию Microsoft (R) WinHTTP
(C) Корпорация Майкрософт. Все права защищены.
Текущие параметры прокси WinHTTP в реестре:
HKEY_LOCAL_MACHINE\
SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\
WinHttpSettings :
Прокси-сервер: proxy2.cbank.kz
Список обхода : (отсутствует)
Последний раз редактировалось ejik_off, 27-12-2016 в 21:03. Отправлено: 07:23, 10-06-2010 | #9 |
Ветеран Сообщения: 611
Профиль | Отправить PM | Цитировать Может попробывать чтобы клиент шел мимо прокси. С помощью proxycfg уберите proxy2.cbank.kz и сделайте прямой доступ.
Отправлено: 09:17, 10-06-2010 | #10 |
| не понятные символы в логах | Shera_Best | ISA Server / Microsoft Forefront TMG | 4 | 01-04-2010 13:28 | |
| Прочее - Помогите разобраться в ЛОГАХ | Endy1 | Общий по Linux | 1 | 27-05-2009 13:13 | |
| Ошибка в логах сайта Модреврайт | venuko | Вебмастеру | 1 | 21-04-2009 23:39 | |
| V. 5.5/2000/2003 - Ошибки в логах | Сет | Microsoft Exchange Server | 41 | 11-04-2009 01:23 | |
| Службы - Ошибки в логах системных событий | Ne-mo | Microsoft Windows 2000/XP | 2 | 26-02-2009 09:46 | |
